Flywheel nut won't loosen, Motor keeps spinning
Old Apr 20, 2016 | 07:22 PM
Pmartone's Avatar
Default Flywheel nut won't loosen, Motor keeps spinning
Hi, I have a bent crank and possibly bent flywheel. How do I get the flywheel bolt off so I can insert the special tool? I'm sure i'm missing something obvious. Whenever i loosen the bolt the crank just turns.
Old Apr 20, 2016 | 10:39 PM
74demon's Avatar
Use an impact gun....
Or put it in gear and have someone hold the rear wheel or the bike if its on the ground.
Old Apr 21, 2016 | 09:47 AM
McBreezyF4i's Avatar
that sounds about right
Old Apr 21, 2016 | 01:01 PM
boredandstroked's Avatar
Some soft rope in the spark plug hole works as well if the valves are all closed.
John Brown
Nov 27, 2013 05:47 PM
playb0i
Feb 6, 2009 08:43 PM
Stephens
Oct 26, 2008 11:28 AM
maxperformance
Jul 11, 2008 09:54 PM
Northernfirepower
Oct 21, 2007 02:27 PM
