Flushmount question
Old Jan 14, 2008 | 12:53 PM
dankryder's Avatar
Default Flushmount question
Hi I just got a pair of flush mount turn signals. They have bolts and sticky tape. THey seem alot bigger than the place the stock turnsignals came from. Do I screw them into the same holes somehow or sticky tape them over the holes somewhere? Any help would be greatly apperciated. Thanks. Heres a link to the ones I got.
http://cgi.ebay.com/ebaymotors/Honda...em350013703898
Old Jan 14, 2008 | 01:30 PM
krash's Avatar
Default RE: Flushmount question
Im not sure, those look alot like the ones that were on my first F4i. in order to get them to fit correctly, the guy before me actually cut out part of the fairing to get them to sit correctly where the turn signal stem used to go. Does it fit in the hole correctly?
Old Jan 14, 2008 | 01:45 PM
Retal's Avatar
i suppose these ones will not fit the stock holes so you will have to put then on sticky tape somewhere else from your stock section
Old Jan 14, 2008 | 03:12 PM
dankryder's Avatar
Hm thats what I was thinking, they don't fit in the stock holes at all. I may just cut out the stock section and drill a couple new holes and screw them in and feed the wires through.
Old Jan 14, 2008 | 04:42 PM
dankryder's Avatar
Whats the best tool to cut the fairings with?
Old Jan 14, 2008 | 06:32 PM
voodoochyl's Avatar
Retired Moderator
Dremmel should work for that application. Maybe tape around the area, and use a different tip to polish out burs when you are done.
Old Jan 14, 2008 | 06:34 PM
sharker98's Avatar
I would get another set, those are pretty large, Hot Bodies can be had for just a few bux more and look factory, perfect fit
Old Jan 14, 2008 | 08:42 PM
krash's Avatar
I went with the hotbodies from ebay, like 29$, perfect fit, but not a high quality product. I needed to resilcoone the wires to the assembly.
Old Jan 14, 2008 | 09:50 PM
vkhamphi's Avatar
Don't cut. Just sell them on ebay and pick up the Hotbodies flushmount. They fit like factory.
Old Jan 15, 2008 | 01:58 AM
dankryder's Avatar
Good call guys definatly going with the hotbodies and saving the time and engergy wrecking whatever I was going to wreck, thx a ton
