flush mount
Old Mar 25, 2010 | 02:53 PM
efeliciano13's Avatar
Registered Users
Default flush mount
hey i just bought some flush mount turn signals for the front and im wondering how the flash is going to be, if there is one at all. what resistors are you guys using because i see different ones with different watts and ohms? also where are you guys mounting them given that they get hot?
whats an alternative to getting a resistor, or is that the best route?
Old Mar 25, 2010 | 02:58 PM
__Z__'s Avatar
April 2011 Ride of the Month
you can do something like this
http://www.amazon.com/Resistors-Sign.../dp/B001MUMPNC
all the leds will do without the resistor is flash faster....
i personally like the leds flashing faster.... my tail lights are led to so they all flash at the same rate....
Old Mar 25, 2010 | 03:17 PM
Registered Users
cool, thanks z. what about a good mounting place for the resistor?
off topic, whats the red light on the left side of the tachometer, is that the kick stand indicator?
Old Mar 25, 2010 | 03:25 PM
__Z__'s Avatar
without looking at it idk what your talking about ha but maybe its the shift light?
as far as mounting anywhere really works... as long as its hidden lol
dmcb2120's Avatar
shift light
Old Mar 25, 2010 | 04:06 PM
Registered Users
Must be the shift light, to the left of neutral. What does that shift light mean exactly, is it bad?
Old Mar 25, 2010 | 04:08 PM
__Z__'s Avatar
lol i take it you havent ran your bike through the gears..... once you get up to your red line the shift light turns on to tell you to shift.... useful when racing and such.... drag cars have them as well if youve ever been around drag racing... same principle
Old Mar 25, 2010 | 04:16 PM
Registered Users
Oh lol I only rode it three times and haven't got the revs that high yet, I only noticed it because its on when I first turn the bike on cause it stays lit for a while, normal?
Any recommendations for frame sliders?
Old Mar 25, 2010 | 04:22 PM
__Z__'s Avatar
ummm im happy with my trex sliders... relatively inexpensive if you have a more money alot of people recommend woodcraft...
as for your light... when you first turn ur bike on everything should light up and your rpm needle should sync
Old Mar 28, 2010 | 10:32 AM
HydroPrelude85's Avatar
i installed the proton flush mount turn signals on the front of my 03 F4i
i didnt use any resistors and they work fine. the stock wiring harness is 3 wires
and the flush mount has 4 wires. i think it was connect just the yellow wire for regular
just the orange for strobe or both yellow and orange for fade in fade out
