FI light turn on
Old Sep 17, 2012 | 05:37 PM
mass-cbrf4i's Avatar
Default FI light turn on
light turned today and need to know how to check code?any help appreciate
Old Sep 17, 2012 | 08:16 PM
RudyGT's Avatar
pretty sure you turn the ignition to run and it blinks. at least thats how mine reacted. ran it, FI started blinking, i freaked out, turned it off, turned the igition on 2 blinks..
looked it up pluged the hose in, and it cleared itself.
http://i47.photobucket.com/albums/f1...codeschart.jpg
im blatantly ripping this off from another forum you will get if you google f4i fi lgiht codes
edit: hell that list is incomplete, remember long blinks 1.3 seconds are 10's short blinks .5 seconds are 1's
Old Sep 17, 2012 | 08:48 PM
Thanks as soon as I get a chance I'm going to try to get the code.
Old Sep 17, 2012 | 10:16 PM
boredandstroked's Avatar
I have no idea how to help you but Im extemely happy to see you call it the FI light instead of the F1 light. I've started telling people who ask about the F1 light that it means the bike is in race mode.
Old Sep 18, 2012 | 09:35 AM
lol
Old Sep 18, 2012 | 02:52 PM
chicken nugget's Avatar
Mine has been doing the same, but only on cold mornings. warm days or later in the day it will not come on, blink or anything. Bike still runs smooth and no other issues other than cold mornings the light blinks and will stay on for the first ride into work.
I am in NH and assume you are in MA, perhaps the same issue as me since we have had some cold mornings.
Old Sep 18, 2012 | 05:28 PM
C Jacob W's Avatar
you can flash the code then after you cut the bike back on it should be blinking the code.
Old Sep 19, 2012 | 07:56 PM
isco6's Avatar
New Member
under the main seat is a two wire plug. I think brown and green. turn the bike off jump the two connectors with one piece of wire and turn the key on and the bike to run. It will blink the codes. I will find the codes and post them if you need them.
Old Sep 19, 2012 | 08:19 PM
It blinked 2 then 9 then 1 long and 9 more does that mean 2 codes a 9 and 19? But I started it today and the FI light turned off and took for a ride ,no Backfire......so I decided to take apart for the season.
Old Sep 19, 2012 | 08:51 PM
isco6's Avatar
New Member
If there's a code, the FI will flash your code(s). Count the flashes.
There's long blinks amd short blinks.
Long = 1.3 seconds
Short = .5 seconds
If you have a long blink, the 3 short ones.....that's 13.
A long blink = 10
A short blink = 1
9 short blinks = 9....and so on.
Let us know....
CODES:
0 - bank angle sensor, ECM, PGM-FI fuse
1 - MAP sensor
2 - MAP sensor vacuum hoses, or sensor itself
7 - ECT sensor poorly connected or open circuit
8 - TP sensor, TP senspr wiring
9 - IAT sensor connection, or open wire
10 - Baro sensor, or connection, or wiring
11 - Vehicle speed sensor, or connection or wiring
12 - #1 injector connection, or faulty injector
13 - #2 injectior connection or faulty injector
14 - #1 connection or open/shorted circuit
15 - #2 connection or open/shorted circuit
18 - Cam pulse sensor, connection or loose sensor
19 - Ignition pulse sensor, connection or loose sensor
20 - faulty E-PROM in ECM.
