Which fender eliminator?
www.pimpbike.com makes a good one. You'll have to go with the integrated tail light though. That makes the back end of the bike look really clean. The stock fender looks like crap.
There's a good DIY FE on here somewhere. It basically mimics the CompetitionWerkes FE & fairly easy to do. In materials, its less than $10. You basically cut off the shovel behind the rear battery tray mounting tabs, bolt up FE, & you're good to go after afixing your plate/signals. An actual CW kit is stainless steel & about $125 or so.
