Feeling the clutch engage
Hello all,
I noticed that I can feel the clutch engage about halfway through the release of the clutch lever and I was wondering if this is normal. My bike shifts normal and I just want to make sure that I don't have the clutch lever adjusted too tight or too loose.
I have the screw on the clutch lever only out about a 1/4." (this gives me very little free play). I think I previously had the screw out too far before (at about 1/2")--making the clutch lever too tight (with no free play) and the clutch was engaging when the clutch lever was barely squeezed (about a 1/4" squeeze).
Basically, my question is, is it normal for me to feel the clutch engage? I mean, I know I should feel the clutch engage sometimes, but at what degree? I am not releasing it too fast, but even when I do release it fast or slow, I still feel it engage. I am just wondering if feeling the clutch engage at a certain amount is normal or not normal.
My bike is an 04 F4i with about 2800 miles.
Thanks and sorry if this sounds jumbled together.
What do you mean by "feel" the clutch engage? Are you feeling it in the lever, or in the change of acceleration? Can you feel it engage with the engine shut off(if you're feeling it in the lever).
As long as your clutch isn't slipping, and the wheel doesn't rotate(there may be a slow rotation) with the clutch disengaged on a rear stand, the point where the clutch engages is mostly personal preference.
You need some free play, or you could toast the clutch. A little more free play will mean that the clutch engages closer to the bars, a little less and it will be further out. The adjustment is really a matter of personal choice. My wife has smaller hands so I put Pazzo levers on her F4i so that the engagement point is closer to the bars than could be adjusted with the stocker, even with a lot of free play.
Drew212,
All of this is when I am riding. I kind of feel a little clunk when I am starting off in first gear. It doesn't happen all of the time, but it does happen after I squeeze the clutch lever to disengage, then let go to reengage.
Skapan,
As for the free play, I have a little, meaning the clutch engages further out than closer to the handlebar.
Skapan,
I don't thing he's talking about the gears engaging, he's talking about when he pulls and releases the clutch lever.
Do you feel the "clunk" in your clutch lever? Check your chain, make sure it isn't too lose, slack in the chain will cause a jerk as the top part of the chain tightens when the front sprocket starts to turn.
Thanks for the input everyone.
I guess another way to think about what I am feeling is, I can feel the clutch plate as it press against the flywheel (I know that is what it would be for a car, but I am not sure if it is the same terminology/mechanics for a motorcycle).
Everything on the bike still feels normal, but I was just inquiring about this because I don't know if this could be signs of wear or not. Since this is my first motorcycle, I am learning different things little by little.
Most of the time, when I disengage the clutch and reengage the clutch and as the clutch plate press against the flywheel, I don't feel it at all and it is very smooth, but sometimes I can feel the pressure of the plate. (now, I only feel this when holding the clutch in, while in first gear and stopped; then when I am about to roll away from being stopped, I sometimes feel the plate as it presses against the flywheel).
I know that all of this is me just learning my motorcycle, but I would rather come here to ask about something I am not too sure of so someone with more experience can reassure me that I am just going through my infant stage of being a motorcycle rider!
Thanks for your help.
I am slowly approaching my one year mark of owning my F4i, and when I acquired it, it only had 2188 miles on it. So at the current pace I am going, that is about 1000 miles/year. I only get to ride to school and, occasionally on Sundays, I ride lonely on one of the highways and into the suburbs of the surrounding areas.
There is not any nice long stretches of curvy roads around here where I live that would be nice for me to ride frequently, so I am forced to make the most of my riding while I commute.
Cheers!
