Fan direction
Old Sep 21, 2010 | 09:46 AM
andy044's Avatar
Default Fan direction
stupid search wont accept "fan" as a search criteria
anyways 2002f4i i re wired my fan to a switch, it works, buuutt not as nice and cool as id like
which way should it be going?
pushing air out towrads the front of bike? or sucking air through exhausting through the fairing vents?
i would think sucking is better than blowing. ha
Old Sep 21, 2010 | 11:30 AM
jp_greenville13's Avatar
you are correct
Old Sep 21, 2010 | 02:31 PM
Bently600's Avatar
Sucking is definitely the way to go
The airflow should be directly at the Radiator.
Old Sep 22, 2010 | 01:30 PM
andy044's Avatar
ya its defingatly blowing out the front. can anyone confirm the stock direction? without using the switch the fan still blows forwards at 226`F
whats really going on here?
if switch the two leads going into the fan motor, i will blow fuse i think
Old Sep 22, 2010 | 02:53 PM
It really is as simple as that. Reverse the power wire with the ground wired and the fan goes the other way :P It's a bit of a concept to explain but trust me. You won't hurt anything!
Old Sep 23, 2010 | 01:47 PM
andy044's Avatar
i understand that for the most part elec fans can be run either way.
im just wondering what the factory fan direction is
Old Sep 23, 2010 | 02:21 PM
R Dub's Avatar
October 2011 ROTM
My best best guess is that it sucks from the radiator and blowing onto the engine. When I am on mine I can put my hand by the vent and feel it blowing. And the radiator doesn't need a fan blowing on it as it as the air blowing on it as you ride.
I rode to work today so I will try to remember to look to see if it is clockwise or counter clockwise on they way home and will let you know.
Old Sep 23, 2010 | 02:29 PM
I can assure you it pushes toward the rad. Other whise all it will do is stop air from getting to the rad at highway speeds. I have never ever seen a fan that doesn't move air from front to back. (I'm a mechanic) Jut trust us on this one man. lol
Old Sep 23, 2010 | 07:11 PM
usetheffours's Avatar
Your right but... the fan is on the back of the rad so it pulls air through.
Old Sep 23, 2010 | 09:45 PM
R Dub's Avatar
October 2011 ROTM
It turns counter clockwise. It pulls air from the rad. and onto the motor.
