Fairing bolt size?
Old Jul 24, 2012 | 02:56 AM
kcrews123's Avatar
Registered Users
Default Fairing bolt size?
I bought a F4i in parts, am in the process of rebuilding it, and I can't figure out what bolt size this is. I bought a full fairing bolt kit but none of them are close to fitting. Its the bolt that my awesome photoshopped arrow is pointing to in the pic:
Uploaded with ImageShack.us
Old Jul 24, 2012 | 04:33 AM
HotWheels's Avatar
Default 8mm Bolt
Hey there. First of all good job posting up a picture with your question. That totally helped hehe. I think I found the bolt that you are looking for. Looking at the Fiche on ronayers.com, it lists this bolt as 8mm. However the exact description of it is BOLT, SPECIAL (8mm) because not all of it is threaded and it does have threads towards the end of the bolt, then its circumference fattens considerably so that it pushes correctly against the side fairing. I'll give you the link to the fiche. If I am not mistaken, the bolt you need is number 8 on the list. I have ordered misc. bolts etc from this site many times before with perfect success. The only downside is if you are buying cheap as in this one bolt etc, the shipping is prob. going to be like 9 or 10 dollars hehehe. >.< Hope this helps. =)
Ronayers.com Microfiche Honda>Motorcycle>2001>CBR600F4>FRAME 99-03
Old Jul 24, 2012 | 09:43 AM
jeffjones's Avatar
Im you have a set of aftermarket fairings it may be loose when the bolt is put on due to the fairings being a tad thinner then OEM, I just bought a rubber O-ring and it fit perfectly snug.
Old Jul 24, 2012 | 03:01 PM
j0hnnyn's Avatar
Do you know which bolt is used for frame slider on a 04 f4i?
Old Jul 24, 2012 | 07:36 PM
kcrews123's Avatar
Registered Users
Awesome, thanks a ton
Old Jul 24, 2012 | 10:23 PM
NVFD740's Avatar
I was getting ready to post this same question. Thank you.
Old Jul 27, 2012 | 05:48 AM
HotWheels's Avatar
You guys are more than welcome. I am glad I could help you out. =)
As far as what bolt is used on an f4i for frame sliders, it certainly isn't going to be one of the stock ones. When you purchase frame sliders you are given a longer aftermarket one that is needed. It will come with directions as well. =)
CP49
Jun 14, 2013 07:55 AM
500tie
Mar 10, 2013 01:39 PM
nykuryu
F2 Tech
Apr 3, 2010 02:18 PM
Chunga
Sep 28, 2009 04:54 AM
CanuckDave
Feb 18, 2007 10:59 PM
