F4i Wiseco Piston Kit
Dont bother, you want to run as low an octane as recommended/possible which i believe is 87 for the f4i. You wont get any benefits from running a higher octane if you dont need it, its just a waste of money and It could cause/increase carbon build up in your engine. Stick to 87-89 unless youre getting engine knock, etc like i said before, then go up a grade.
Higher octane fuel doesnt give you more power it just combusts at a higher temperature/pressure/not sure of the word to use here. You just need it for higher compression, forced induction, applications and such where a lower octane fuel would combust before the end of the compression stroke(premature detonation). So if youre running a higher octane when you dont need to youre not combusting all of the fuel sooo the rest of it is going to start to become carbon build up and its also just a waste of gas and in turn a waste of money. Some google or forum searches about this should give you a much better idea what im talking about. Ive been up for about 35 hours straight at this point...i hope im making some sense.
LOL...pushing your limits are you?...don't push your self too much. lack of sleep can really do a number on you. ...and thanks for the info...ill search around for more on the fuel and octane. Thanks Nick!!
haha yeah im just tryin to wait till 10 or 11 so i can pass out and wake up around 9 or 10 and get a normal sleep cycle back. If i bit*h too soon ill end up waking up at like 5am and then ill still be in a messed up sleep patten for a few weeks. haha ive gotten it down to a science over the past few years.
It comes down to the tune for using higher octane. For example my summer car is a Ford Zx2. Since its a typical car it uses 87 octane. But why am I using 92 plus? Most tune's on a vehicle/bike come down to timing. Since I am pushing around 40 degrees advance vs the stock 20 degrees it needs to using a higher octane to work with the spark advance to prevent detonation. Hopefully this gives you a idea on why you would use higher octane.
Quick google search brought up this. http://www.orientexpress.com/product...oducts_id=5627
12.8:1 vs stock 12.0:1 compression ratio.
ill have to wait and see how the bike does when i get it out of the shop. i hope there is a benefit of it though. Thanks for the info everyone and the link to the wiseco site. Perfromance wise the bike will be plenty enough for me regardless. Im really looking forward to it though!!
