F4i Starting Problem
What's up everyone, wanted to see if I could get your guys inputs. I'm driving a stunted out 2001 CBR F4i. For the past 3 weeks, I've had one of my spark plugs(2nd one from left to right) pop out during driving. Each time I put it back in and it ran fine for the rest of the day, it's happened probably 4-5 times, and I now carry my tools with me so I can put it back in whenever it pops out. Finally looks like I tightened it enough so it no longer pops out, however now I have a new problem. Last night while driving on the highway, the bike started feeling/sounding it was loosing power or choking. My first thought was maybe I put in bad gas, but I managed to limp it home. Now today in the morning, went to go turn it on and nothing, I heard the fuel pump prime but when I clicked the startor button, no sound, no click, not even an attempt to turn on. Managed to bump start it fairly easily and was on my way, got a few miles down the highway before the same problem started happening, where the bike felt like it was losing power. Thinking again bad gas, I downshifted from 6th and gave it full throttle, and the choking started happening even harder. Eventually the bike died on the highway, and no attempts to bump start it worked. My first thought was the fuel pressure regulator, however as to why the bike won't even turn over doesn't make sense to me. Even if it was the regulator I'd expect the bike to atleast turn over, and when I turn the key I can hear the regulator priming. Any advice or things to check? Thanks in advance everyone
Check your charging system. That's exactly what happens when a regulator/rectifier or stator fail.
The plug keeps popping out because the threads on the plug or the threads in the hole are damaged. |
