F4i Rear stand...help
Old Jan 7, 2008 | 12:18 AM
Allamericantc's Avatar
Default F4i Rear stand...help
Hey guys,
I just picked up a rear stand for the bike. Assuming the swingarm had predrilled holes for the spools, i went to put the bik eup and there were know holes. What do i need to modify?
Old Jan 7, 2008 | 06:58 AM
krash's Avatar
Default RE: F4i Rear stand...help
F4i's do not come with spools. cheapest and easiest thing to do is take the stand back and get one with pads that fit under the swing arm.
Or you can take your swing arm off, have someone weld bungholes for the spoolsonto it, then repaint it, then remount it.
You can also drill out the swing arm, and insert special thread inserts into it, but thats kinda iffy. There was a guy that did it on another board
with a few pics and then low and behold, he crashed his bike. the inserts actually held up. do a search over on cbrworld.net and guy named sebspeed
Old Jan 7, 2008 | 07:34 AM
Tahoe SC's Avatar
ORIGINAL: krash
wow...i just couldn't get past this part! ;-)
Old Jan 7, 2008 | 09:01 AM
Jump1979man's Avatar
If you got a DMP Stand you can buy the paddle hardware to use instead of the spools.
Old Jan 7, 2008 | 10:15 AM
tollfree969's Avatar
Do you have to take the swingarm off to weld in "bungholes?"
Anyone have pics of it done on an 02 F4i?
Old Jan 7, 2008 | 12:25 PM
CBR Time's Avatar
Like Krash said, i would take back, get one w pads, thats what i have works well
good luck
Old Jan 7, 2008 | 01:09 PM
krash's Avatar
ORIGINAL: tollfree969
I guess that would be up to the guy welding it, but I am sure he is going to charge you 3 times a much to do it on the bike, plus you still should paint it becuase it will ruin the finish. Not to mention, all that heat may have adverse effects on your tire. by the pads
Old Jan 7, 2008 | 01:30 PM
cwmc29's Avatar
Just go on to eBay and buy these. There is no modifications needed to the bike and you just remove them when you go for a ride. I have used them for the last couple of years with no problems at all. Here is the link and a pick.
http://cgi.ebay.com/ebaymotors/Axle-...spagenameZWDVW
Old Jan 7, 2008 | 01:32 PM
krash's Avatar
OK so how do take off your back tire?
Old Jan 7, 2008 | 02:07 PM
thegame's Avatar
haha. u guys said bunghole
cwmc29- u scottish too?
