F4i Gripes...
F4i Gripes...
Number one, the manual should tell you need a damn screwdriver that is ten inches long for the throttle body removal. ARG!! I hate extra trips to the store.
And two it is damn hard to get the throttle bodies off when the intake boots are cold. I had to loosen the top screws then pry them off with a damn screwdriver.
I have the clymer manual. IT said you need a long phillips screwdriver, Well i had one that was 8 inches long but apparently you need one that is atleast 8 and a half inches long. oh well. its all apart now. just ahve to worry about getting the cams back on time after i take it apart and making sure all my hoses and plumbing go back in correctly. Cant wait to hear it purrrr...
And i forgot, the one thing that pisses me off the most.. I cant take the coolant reservoir out without taking off the entire rear subframe? what the hell is up with that? Why couldnt they put it in the front of the engine like the euro model or whatever. BS!!!
just putting coolant in the damn jug is aggravating enough.
yeah but its only like a couple screws to take off the side fairing. You can barley see the coolant reservoir as it is. Maybe im wrong, i never really even looked at it before. I just want to take it out and wash it so i can put it back on the bike fresh and clean like everything else. Im wondering if i can just unbolt the shock from the frame and get the reservoir out with the shock out of the way.
