F4i bucking when accelerating
I just had the chain and sprockets replaced. When I try to accelerate faster than normal the bike starts to sputter and the FI light comes on. The tach also dips to zero then back up and down.
All this lasts about 2 seconds or so and then it rides normally until I decide to accelerate hard again.
Also at times when I come to a stop or if I brake hard, it'll the FI light will come on and the bike will die.
My bike idles around 1000-1100 when fully warmed.
Anyone have any idea as to why this is happening? Could it be the mechanic messed something up while replacing the sprockets and chain?
I'm freaking out because I just spent $500 for the chain/sprockets and an oil leak fix.
That's exactly what it is. You're fouling plugs/flooding the motor or it's not getting enough fuel, either one isn't good. Hesitation only happens with a fueling issue. Chains and sprockets aren't to blame here. If you just got the oil leak and everything else fixed, I would get the fuel system checked out. Pump, injectors, etc.
$360 for chain/sprockets/labour
+insane canadian taxes
Also I tried turning up the idle by turning the little screw behind the left fairing but it wouldn't budge.
It's just weird that the bike NEVER showed signs of this before I took it to the mechanic. and a day after he brought it back...it starts doing all this. Maybe it's a coincidence?
The oil leak was because the timing cover needed to be resealed, not sure if that has anything to do with this issue.
I guess I'll call him again and tell him to look at it.
Idk what kind of chain and sprockets you bought, but they must be made out of a gold/cocaine alloy. Damn.
EK gold chain and Aluminum sprockets (-1+2) = $270
labour = $80 to diagnose and reseal timing cover (oil leak) + $70 chain/sprockets
+ insane canadian taxes
= $480ish
Did I get ripped off? I was planning on taking the bike back to him again for the bucking problem
