F4i bucking when accelerating
I just had the chain and sprockets replaced. When I try to accelerate faster than normal the bike starts to sputter and the FI light comes on. The tach also dips to zero then back up and down.
All this lasts about 2 seconds or so and then it rides normally until I decide to accelerate hard again. Also at times when I come to a stop or if I brake hard, it'll the FI light will come on and the bike will die. My bike idles around 1000-1100 when fully warmed. Anyone have any idea as to why this is happening? Could it be the mechanic messed something up while replacing the sprockets and chain? I'm freaking out because I just spent $500 for the chain/sprockets and an oil leak fix. |
$500?!?! What the hell did they do?
Why is your idle so low? I keep mine just under 2k and it seems to run best there. 1.5k or lower and it searches for a steady idle and causes hesitation problems. I reckon if you adjust your idle up it will solve your problem. |
The manual says rpm's should be at 1200-1400.
Sounds like you have a different problem that is entirely unrelated to your chain and sprocket. Sounds like a fueling issue. Almost like a major hesitation where one or more of the injectors isn't getting the fuel its demanding on request.
Originally Posted by Syphen
(Post 1044202)
Originally Posted by F34Me?
(Post 1043946)
Why is your idle so low? I keep mine just under 2k and it seems to run best there. 1.5k or lower and it searches for a steady idle and causes hesitation problems. I reckon if you adjust your idle up it will solve your problem. $360 for chain/sprockets/labour +insane canadian taxes Also I tried turning up the idle by turning the little screw behind the left fairing but it wouldn't budge. |
Originally Posted by Junior2552
(Post 1044206)
That's exactly what it is. You're fouling plugs/flooding the motor or it's not getting enough fuel, either one isn't good. Hesitation only happens with a fueling issue. Chains and sprockets aren't to blame here. If you just got the oil leak and everything else fixed, I would get the fuel system checked out. Pump, injectors, etc.
It's just weird that the bike NEVER showed signs of this before I took it to the mechanic. and a day after he brought it back...it starts doing all this. Maybe it's a coincidence? The oil leak was because the timing cover needed to be resealed, not sure if that has anything to do with this issue. I guess I'll call him again and tell him to look at it. |
Originally Posted by 95teggy
(Post 1044218)
$80 for oil fix
He included labor in the price of the chain and sprockets. Figure $180 for the chain and sprockets and another $180 to install (and repair a leak in the timing cover? what the?) lube and tension.
Originally Posted by Honda125 358
(Post 1044492)
Idk what kind of chain and sprockets you bought, but they must be made out of a gold/cocaine alloy. Damn.
(Post 1044507)
EK gold chain and Aluminum sprockets (-1+2) = $270 labour = $80 to diagnose and reseal timing cover (oil leak) + $70 chain/sprockets + insane canadian taxes = $480ish Did I get ripped off? I was planning on taking the bike back to him again for the bucking problem |
