F4i bolt questions
F4i bolt questions
I'm in the process of changing out the plastics on my F2 with F4i parts. I have them all purchased, but I don't have any bolts. How does the tail light mount to the split-seat F4i rear? I've been looking at the subframe and can't figure it out. Maybe someone could snap some pics and post up?
RE: f4i bolt questions
These microfische pics are the only ones I've found, to kinda show how it attaches...
The taillight has 2 studs that stick straight out the back, and then the battery tray has 2 holes in the back with rubber grommets and a washer on each side of it, and it bolts in with (2) 10mm nuts. It's different than the banana seat F4i taillight which screws directly into the tail plastic, this one attaches to the battery tray before you even put the tail plastic on.
Hope that helps some
