Originally Posted by kowen1208
(Post 919762)
Don't blame you for wanting to do this swap. That is one sexy cluster.
As for testing amperage, you can also do it with a digital multimeter, but it requires interrupting the circuit (cutting the wire and inserting the DMM lead to close the circuit). and dont think there will be a need kowen... if i get that repair manual it should have all the amperage i need... shouldnt it??? |
Why not remove the cluster and make a custom dashboard (since this is a Ferrari build) and use something like a Tiny Tach.
http://www.tinytach.com/tinytach/gasoline.php |
lol this part is more for my personal eye bling than the ferrari build itself... that is a good idea but not my personal style... plus i still wanna have my Fi light so on and so forth...
Originally Posted by zmds18
(Post 919764)
Really, you're more likely to fry your cluster than anything else. Stuff like LEDs, computer components that operate the tach, speedo, etc. I'm not meaning to deter you from doing the swap, just trying to help you be aware of all the things you may need to look for. I've been working on a car alarm install, and if I've learned one thing, it's that electronics (aside from plug and play stuff) are never very straightforward, unless you just happen to be an electrician. Even then it can be sketchy. |
(Post 919768)
It might. I got some wiring schematics for my car straight from the dealership and it didn't list amperage.
Really, you're more likely to fry your cluster than anything else. Stuff like LEDs, computer components that operate the tach, speedo, etc. I'm not meaning to deter you from doing the swap, just trying to help you be aware of all the things you may need to look for. I've been working on a car alarm install, and if I've learned one thing, it's that electronics (aside from plug and play stuff) are never very straightforward, unless you just happen to be an electrician. Even then it can be sketchy. makes production cheaper im hoping this is one of those standards... |
Just need to see what fuses in the kawi
Originally Posted by dmcb2120
(Post 919778)
once all the facts are combobulated together..... If it works I Shall Do A Write Up.... Perhaps ;-) or keep it all to myself muahahaah jk |
(Post 919778)
**** it send the whole wiring diagram page Dmcb2120@gmail.com
sending as we speak... its a monster
