f4 bike, stupid f4i fairings..bulbs?
![Exclamation](https://cbrforum.com/forum/images/icons/icon4.gif)
i know that the f4i takes the h7 bulb, BUT what i need to know is, i heard something like the f4i's have bulb adapters on the harness??? since mine is an f4 not a 4i, i have i rigged harness , i have a positive and a negative with female ends that attach to the male ends on the bulbs.. im pretty sure i have f4 bulbs because they are really loose in the 4i light housing.. so i guess the questions are..number 1..do the h7 bulbs have two male prongs i can just connect my ghetto harness to and it will be ok? or..2.. do i have to use the stupid adapter? HOW CAN I MAKE THIS WORK! tia lol
steve
steve
F4 Bulbs are H4, F4i are H7.
The H7's have a two male prongs that you could hook up directly.
The reason the may be loose in the housing is you might need a spacer on the bulb.
I can't get to the picture, bu tI believe it is on this write-up, I just can't open it on my work computer.
https://home.comcast.net/~nstama/hidinstall.html
i need to put the h7 bulbs in the headlights, when i got the bike it was half way done with the 4i swap and this is the last thing i have left, now i hear there is some kind of adapter that the bulbs plug into? my harness is two wires, power and ground for each bulb, the h7 has 3 prongs so im assuming that the adapter converts the 3 prongs into 2 prongs? or could i just use my power and ground i have now, and just leave a prong exposed on the h7 bulb? i have all my wiring done, im just trying to figure out how i will make the prongs work..
