extra watts?
Old Oct 21, 2007 | 03:11 PM
rodantking's Avatar
Default extra watts?
Can't find how many volts (sorry watts)the stator puts out. Can anyone help out.
Old Oct 21, 2007 | 10:55 PM
FLYOU's Avatar
Default RE: extra voltage?
not sure. i know 6 volt batteries get a 7 volt alternator
12 volt batteries need 14v alternator
24 volt batteries need 28v alternator etc
that's how it is on airplanes anyway. i don't do cars or motorcycles very well. [sm=sorry.gif]
if the f4i has a 12 volt battery, i'm guessing 14 volts and, i dunno, 30 amps?
anyone wanna jump in and corret me?
Old Oct 21, 2007 | 11:37 PM
rodantking's Avatar
I
Old Oct 22, 2007 | 12:19 AM
axsys's Avatar
i have measured mine with a voltmeter and it is almost exactly 14. i dont know if it will be for every bike but considering what FLYOU said i would assume so.
Old Oct 22, 2007 | 02:17 AM
FLYOU's Avatar
yeah, i'm pretty sure it's 14.
Old Oct 22, 2007 | 03:14 PM
ampfp's Avatar
It should be around 14Vdc, that's post-regulator though. By itself the stator puts out an (alternating current) 'ac' voltage (hence the correct name 'alternator' to the entire assembly)(if you're trying to measure directly across its terminals) ... and then the effective voltage depends on what you measure, the peak, avg or rms. Most meters do an approximate RMS measurement.
Old Oct 22, 2007 | 03:35 PM
Jaybird180's Avatar
Does the regulator steady the current also? I believe that 3000 rpm is the magic number to charge the battery.
Old Oct 22, 2007 | 05:01 PM
rodantking's Avatar
Sorry guys, I meant watts not volts.
Old Oct 22, 2007 | 07:12 PM
white99gt's Avatar
WHat are you trying to run on the bike?
Old Oct 22, 2007 | 07:28 PM
rodantking's Avatar
I set up my bikes with heated grips and plug-in for my heated jacket. Would have to look it up agian to be sure, but I believe it's about 100 watts for both. I could switch to HID's get to some back if I need to, but I like to be on the safe side of power draws.
