Exhaust leak or something else?
At that mileage it is due at the very least a valve check.
It is relatively easy if a little tricky due to limited space to do the checks. If any adjustments are need that is more tricky but still within the scope of a competent home mechanic.
The valves on this machine are of the 'bucket and shim type' not the more common lock nut and adjuster type. It involves removing the cams to get at the appropriate valve and replacing the shim.
There is a guide on the stickie
https://cbrforum.com/forum/stickies-...-101969/page2/
The following users liked this post:
blackwoodrebel (06-10-2021)
Out of curiosity..does this bike sound OK to you guys?
I can hear the same "ticking" sound i hear on mine but a lot louder :
https://www.youtube.com/watch?v=zEEt...astianzatorski
Valve clearances should be checked around 16,000 miles. I checked mine at 20 and all but two or three were tight, so the chances of the clearances being too loose and causing the ticking are... very slim (see what I did there?)
![Big Grin](https://cbrforum.com/forum/images/smilies/biggrin.gif)
When I decided to tackle the job I watched this -
Yes, that sound clip "sounds" normal. I will say that if I've done a major job on the bike, I always think it sounds raspy and clattery the first couple of times I start it back up and worry I messed something up. Wife and kids are always like "No, it's always sounded like that!" lol...
Okay, thanks - i will try and at least take a look at it and see if i can manage it.
Anyways, the plan of action for now is:
1)Change the exhaust gaskets (already ordered)
2)Change the valve cover rubber gasket (the black stuff under the exhaust seems to have been oil..i cleaned it up real good and after a long drive i saw a drip of oil) - maybe also take a look at the valves then a bit..
3)Change the spark plugs
Hopefully anyone of these will help.
I already found myself struggling with another issue, namely it seems that my front brake loses pressure over time.
If i have not used the front brake for like an hour it will almost "bottom out" when i pull the lever and will not "spring" back after i release it, even if i push it back up it remains "limp" (as in it will not stay up but drop straight back down). I need to pump the brake then for a while and the pressure is re-built after that. If i then press the brakes the lever will go back up but it will stop like a few cm before being in the fully "closed" position and then after a few seconds it smoothly goes into the fully closed position.
Not sure if this is a symptom of having air in the system or something else but i ordered a vacuum pump to try and properly bleed the brakes..maybe i should even check the master cylinder out as i just a few months ago changed all the fluids..
