ECU Pink Wire 9V OR 12V?
Old Feb 27, 2013 | 08:59 PM
Taw1985's Avatar
Did not know Honda could do the keys with Vin#'s....This is actually a great suggestion and I will try this method first before I pull the tank off.
I just got her running....well aside from waiting for the new ignition switch and front fairing to come in...I really hate to tear her down again until I least ride her for a few hours. So far I've only gotten 3 hours total of riding time in before the ignition diode went out on me.
Once I get the new fairing and paint them like i want I will post pictures up.
Right now shes all naked with just the tank attached.
Old Apr 7, 2018 | 07:16 PM
Jason McDonald's Avatar
Originally Posted by Taw1985
Thank You! This is most likely the source of no ignition / fuel pump. I am searching for the 9V battery bypass method now along with how to replace this diode if that fails.
I'm having the same problems with my bike it's a 2001 cbr 600 I'm getting no spark and no fuel pump turning on dunno what to do but I've replaced every thing on the bike except the ecu are there a resistor that needs to be replaced
Old Oct 5, 2019 | 07:18 AM
gem ini's Avatar
New Member
check voltage coming from pink wire located at the ignition switch...it should be 9v...if goes to 12v,replace the 3v zener diode soldered inside the ignition switch
Old Apr 19, 2020 | 08:59 PM
redpitdog70's Avatar
Replaced the Diode!!! The Pump powers on! Now to roll her out the APT to crank her
update on this ? Where did you find the diode?
Old Apr 19, 2020 | 09:25 PM
74demon's Avatar
it's on the switch where the pink wire is attached to it.
Old Aug 17, 2021 | 08:08 PM
Tonytatted's Avatar
Default Bought 01 cbr 929 harness OS hacked a
I got this 929 in a trade and I've never heard it run the wiring harness has been hacked so I took a wiring harness part checked it all got it all back together there's no key for the bike I pulled the ignition pulled the Tumblers I got it to where the ignition it turns by turns on no fuel pump still no injector fire I don't know what to do I'm at when Whit's End
Old Dec 11, 2021 | 03:28 PM
AlienVision's Avatar
where did did you get the zener diode at because I ordered two different ones from two different companies and neither one of them worked but when I connect a 9 volt battery I seem to get Spark but the zener diodes are ordered that says 9 volt diodes does not seem to work and I believe they only go one way you can't flip the dial to round it won't work it only goes One Direction. So I tried both directions you can use the voltmeter. Still do not get 9 volt as it says it would so where did you get yours if it . How much was it?
Old Dec 12, 2021 | 12:51 PM
Is it not a 3v zener diode that is required to bring the voltage down from 12 to 9. Not a 9v zener diode which would bring the voltage down from 12 to 3?
vitus detritus
Oct 27, 2020 06:08 AM
Roger cbr
Jan 20, 2014 01:58 PM
gotama
Dec 11, 2011 12:36 PM
ronaldlfox
Aug 23, 2011 12:36 AM
Blackstar
Sep 9, 2010 03:38 PM
