Dual Port USB Power Adapter - illuminated & weatherproof
I installed this probably 6-8 weeks ago. It is a little pricey at $40.(Free Shipping) But it was the only one I could find like this. (Illuminated with dual USB ports) I installed it the dash, but be careful, I cut a little fast, not making sure there was space behind the dash. I cut a piece of non support, plastic off headlight assembly, and it fits great. Another reason I picked this assembly, It is illuminated, so you can always tell if power is going to the plug. Easy troubleshooting if ever a problem!
Here is the link!
Motorcycle USB Power Socket
It does also come with a handlebar adapter as well. If you do not feel comfortable making the cut.
Here is the link!
I've been piecing together a setup in my mind to accomplish exactly this in the very location you selected! Thanks! I have a couple questions for you though: do you know if these USB ports are dedicated charging ports (pins D- and D+ shorted)? Did you tap into the headlight power wire to provide power to the ports?
I'm going to mail them on the dedicated charging capability (D- D+) but I think I'm getting it for my bike since the power requirements for what I plan on using it for will meet my needs (I may have to get a different USB cable if the D- D+ pins are not shorted but that's not a huge cost). Looks like there will be another '06 F4i with an identical setup soon.
Awesome!
adapter, charging, dual, electrical, exhaust, f4i, handlebar, honda, illumination, motorcycle, port, power, socket, usb, waterproof
