does anyone know how to bypass a diode or where i can get one
Old Dec 16, 2010 | 10:04 PM
jp_greenville13's Avatar
yessir. Or pull whatever fuse is on that circuit.
Old Dec 16, 2010 | 10:41 PM
statechamp152's Avatar
i hooked the reader to the zener diode and it read 1 volt when i put it on 9v and when i put it on ohm it went to the right to the 0 side does this mean its bad
Old Dec 16, 2010 | 11:12 PM
I'm not real sure what it is you're trying to say man. If you're checking a diode then forget about volts for a bit. And forget about your 9v range on your meter as you're working on a 12 to 14 volt system. Set your meter to ohms. Check it in one direction and then reverse the polarity of your test leads and check it again. Report back with what you find.
Wait: You're using an analog meter aren't you? Go buy a DMM
Old Dec 17, 2010 | 12:03 AM
nickp123's Avatar
Yeah the ignition diode is a zener. To check the diode he has to look at the voltage of that pink wire that the diode is supposed to drop down to 9v. If its 9 then thats not it but if that wire is reading 12+v than it is the diode. I think were all on diffferent pages here
edit: I think when i did it i just put one prong from the volt meter on each post that the diode is soldered to to check the voltage going through it.
Old Dec 18, 2010 | 08:37 PM
Default diode
okay i did that and i only got 1 volt and when i set it to okm it went to the zero side
Old Dec 18, 2010 | 11:35 PM
Piranha's Avatar
Your basic Diode is used to allow DC current to flow in one direction and not in the other. Used to protect circuits. I would not try to bypass this. I would not do anything with it unless its broken. If you need a new Diode. Whether its a basic or zener diode you can get them at Radio shack for cheap.
Old Dec 19, 2010 | 12:26 AM
Default diode
yeah i tried radio shack which one will work they dont carry a 9v or 3.4 what kind there would i get
Old Dec 19, 2010 | 03:16 PM
nickp123's Avatar
Its a 2.2v zener diode. Ive heard people say the 3.4v zener diodes work as well but im not positive. I replaced mine with a 2.2v one and havent had a problem since.
Old Dec 20, 2010 | 09:42 AM
brveagle's Avatar
resistors will also get the job done.
Old Dec 20, 2010 | 07:26 PM
Default diode
what kind of resisters 9v ???
