Different Clutch Noise
Old 06-08-2007 | 10:43 PM
axsys's Avatar
Default Different Clutch Noise
alright guys, ive got a new clutch noise i wanna ask you about. when im riding at any speed above 40 or so, i hear as noise when i pull in the clutch. as im coasting down the road, i hear an intermittent rubbing noise. it goes on and off as long as i have the clutch pulled in, and also when im in neutral, but changes with the speed that im going (going faster=faster speed of rubbing). it doesnt just do it once, but keeps doing it on as long as the clutch is engaged. it kinda sounds like the normal noise that your disc brakes make from just rolling around (the slight friction noise of the pads slightly pushing on the rotor), but its coming from the engine. as soon as i start to let the clutch out, the sound goes away. anyone ever heard of a noise like this?
________
1CherryLady
Old 06-09-2007 | 05:40 AM
F4iT's Avatar
Default RE: Different Clutch Noise
did you replace the clutch yourself ? you could have a cracked disk
Old 06-09-2007 | 05:46 PM
chpsk8er630's Avatar
might be just your chain against your sprocket. When you pull the clutch in it lowers engine noise so you can hear it. just a thought. Maybee clean and oil your chain and see if that helps.
Old 06-11-2007 | 06:48 PM
Jaybird180's Avatar
Patient: Doctor my elbow hurts when I do this
Doctor: Don't do that
Why would you coast? You could leave yourself hanging out there if you needed to get on the gas. Too much to think about (rpm matching, clutch engagement, turning, object avoidance, target fixation, etc.)
csp
07-10-2011 11:53 PM
CKcbr600fm
07-26-2010 06:53 AM
tecatesr330
12-12-2009 11:28 PM
shoemjay
01-20-2008 03:10 PM
Da CbR KiD
07-11-2007 10:08 AM
