clutch noise?
Old 12-19-2008, 01:59 AM
tecatesr330's Avatar
Default clutch noise?
i noticed when i start my bike (96 cbr 900rr)it makes a ticking type of noise.but if i pull the clutch in it goes away,and goes away after the bike worms up.it has dry clutches in the bike,and was wondering if any one has a idea what it can be or if its normal when cold.
thanks.
Old 07-29-2009, 08:26 AM
kiai's Avatar
dry clutch kit hmm where did you get that ? the sound your reffering to can be many things 1st clutch basket or springs laso look into syncing your carbs and see if it goes away I had same noise I know the carb sync part is wierd but mine magically disapeared after I synced those carbs
Old 07-30-2009, 05:03 PM
toddmonster's Avatar
you do not have dry clutch you have the same as every other 900rr wet clutch if it is dry then you have a big problem, get in there and tighten it up and you will be fine
Old 12-12-2009, 10:28 PM
robertcbr's Avatar
Do you have a "how to" for this job?
csp
07-10-2011 10:53 PM
CKcbr600fm
07-26-2010 05:53 AM
shoemjay
01-20-2008 02:10 PM
Da CbR KiD
07-11-2007 09:08 AM
axsys
06-11-2007 05:48 PM
Quick Reply: clutch noise?
