CRG Lever Install - What Parts To Use From Stock Levers?
Old Apr 2, 2020 | 12:06 PM
thatonecbr's Avatar
Default CRG Lever Install - What Parts To Use From Stock Levers?
My bike currently has some cheapo levers installed from the previous owner. I ordered a set of CRG levers, but I have read that CRG (and Pazzo even) levers require the bushings from the stock levers to be swapped over. My question is, what exactly would need swapped over from the OEM levers, and can those parts be purchased separate from buying the entire lever? I do not have the OEM levers, as the bike already had cheap aftermarket ones installed.
Old Apr 3, 2020 | 07:58 AM
MomosF4I's Avatar
Yes, you can buy the individual parts and don't need to buy a whole OEM clutch lever. Here is a link to the parts diagram: F4i parts diagram for controls and levers
If the cheap levers on your bike didn't use the factory lever pivot bolt (number 14 in the diagram and the appropriate sized nut) then I assume you need at least that for the CRG's if they don't come with their own hardware.
TWOFERJUAN
Jul 20, 2010 05:17 PM
chetman7
Nov 25, 2009 05:24 PM
hiimthehandyman
Sep 25, 2008 09:58 AM
Victor1067
Sep 17, 2007 05:28 AM
cbr_racin123
Dec 10, 2006 03:52 PM
