Coolant leaking??? Should Be Terrified... Pics of leak
Ok here it is. I took my plastics off today to do some spring cleaning, getting it ready for the weather. Turned her on and let her run about 15 minutes. Was inspecting the bike without the plastics, see if anything is leaking, and noticed this faint white smoke as if oil is burning off. I investigate and find that it's this green liquid, so I'm 99% sure its coolant. I'm going to be flushing the coolant soon also.
Here are the pics if anyone can help me figure this problem out, the drip is very slow and im thinking its just a loose bolt somewhere, but before I do anything myself, i want some opinions.
[IMG]local://upfiles/15768/6FE1AD8A38274CF08FD65008D067AE9F.jpg[/IMG]
[IMG]local://upfiles/15768/A3B7308ED60C4CAAB1835E109A3AF8DB.jpg[/IMG]
Please ignore the mess under there, I'm cleaning !!!
Thanks for any help guys.
RE: Coolant leaking??? Should Be Terrified... Pics of leak
lol - aside from being poison it's fine to taste.
Where did the coolant come out... if you overheated it then it is no surprise... don't idle it for 15 minutes either!
Coolant is much easier to flush/fill than most people think... the hardest part is getting rid of the old stuff and finding the RIGHT new stuff. The local dealership will cost more, but it will be the right stuff. Be very carefull of you go to the local autoshop that you don't get stuff with silica... that'll chew up your water pump.
I did a diy coolant flush/change. It looks good so you might just need to flush it once. Try and follow the trail of white residue (dried up coolant) i can see its higher then the bolt in the 1st pic.
Check both of those hoses make sure there on all the way and tight. If not it seems like someone might have done a coolant flush before and it seems like its been leaking for a while. Id check to make sure that bolt is tight. I believe its 9.3 ft lbs
ORIGINAL: FLYOU
was there any crusty-white residue on the outside of the hose at all that you cleaned? it looks like there is a little bit in that 2nd picture...
I wiped the area clean, and no leaks, It seems to only show after running it.
Also, what is the weep hole? The little square hole right there on the water pump?
