coolant leak
hmm... the stator thing is different. randyjoy mentioned something about a drain plug between the cylinders. I'd follow up on that. You say you went to work and found the leak in the same spot? If you didn't ride to work that'll prolly mean it's a hose or a bolt somewhere. Without the stress and pressure of the engine running, it'll be something weeping where ever coolant sits.
If you cleaned the entire engine and it's leaking without the bike running, you should be able to trace it with your finger back to the point of origin.
cylinder drain bolt is to the right, the stator cover is to the left. no relation.
im going to give the gaskets a shot, if not, then ill replace the hoses. like i said i ran the bike when i got home and still, nothing. it doesnt present itself until its been sitting there for a while.
dude, i thought about that too but i cant trace it. i mean the way ive been following it i would conclude that its a gasket. about the stator, idk man, maybe it just travelled some how but it still follows the gasket lines and thats why i asked if there is coolant in the stator thing.
Sorry, didn't make myself clear. The bolt at about 3 o'clock on the water pump is the water pump drain bolt (not the one you're pointing to, but to the right). It should have a crush washer. The one you're pointing to does not have fluid behind it, it has to pass a gasket if it is actually leaking near there. Only the drain bolt has fluid behind it, the other bolts are just attachment points.
The cylinder head drain bolt is up close to where the cylinder head is, just above the split, kinda centered on #1. It too should have a washer. It could be running down to the stator, at least it is something to check.
No coolant in stator.
so my wifey decided to surprise me and dust powder along the water pump and stator cover gaskets because she thought it would reveal the leak, but it did not for one and two she crossed the boundary of man and machine, this isnt csi. i freaked out!!! nevertheless it didnt even leak then i cleaned the powder off and waited a few hours and no leak, so i believe it is the gasket given that the powder probably clogged it. so i ordered the stuff and should have everything done by next sat... wish me luck.
randy i have no idea where youre talking about for the cylinder drain bolt. i think i know but not positive.
ok so i changed the gaskets, need to pick up some coolant in the morning to refill but i have a question. it was difficult to get the radiator cap off due to the air ducts but i got it off. now how do i get it on, i dont think i can squeeze it back in. i tried figuring out how to remove the duct with no luck, then i tried moving the radiator with no luck. i can get the radiator off that one grommet near the radiator cap. help!
