convert 05 tail to an 04 tail?
Old Dec 3, 2005 | 06:56 PM
w_guza's Avatar
Default convert 05 tail to an 04 tail?
I was curious if it is possible to convert the 05 (banana seat) tail to an 04 (split seat) tail. I was wondering if all the bolts and clips matched up or not with the frame and stuff. because i want to switch my 05 to a split seat. thanks in advance.
Old Dec 4, 2005 | 06:16 AM
xmunxjai648's Avatar
Default RE: convert 05 tail to an 04 tail?
u mean 01-03 seats rite?? 04-06 is the same seat...u'll need pretty much everything from the gas tank and on...search around theres been previous post about this
Old Dec 4, 2005 | 04:16 PM
w_guza's Avatar
I know i'll need everything from the gas tank back but i was wondering if the screws and clips from the plastics will match up with all the same holes on the frame and stuff. Because i just want to change the plastic to get the split seat but i didn't know if it took any major modifications to the frame and or anything.
i tried searchin but didn't find what i was looking for.
Old Dec 4, 2005 | 04:25 PM
L8X's Avatar
L8X
im sure it'll look pretty sweet! there actually was a previous post on this. i think i was the one that started it, you can search my name maybe? this was earlier this year though. be sure to post pix when ur done though!
Old Dec 6, 2005 | 09:43 PM
w_guza's Avatar
so i pretty much have to get a new gas tank all plastics and lighting and seat? Then everything else will fit right on there right?
can i swap everything from a 01-03 cbr, did they change the frame or anthing inbetween that time?
Old Dec 8, 2005 | 06:30 AM
UMM. NO NEED TO SWAP TANKS same from 01-06...u'll need the rear sub frame, tail light, rear cowl, undertray(battery box),seats...and i think u'll might need the rear half for the wiring, not sure? might be wrong.....or for short get everything that bolts on the subframe(including the subframe)
May 7, 2008 02:42 AM
st.george
Sep 27, 2006 04:33 AM
Reemo_2001
Jul 3, 2005 03:00 AM
