Clutch adjustment?
Old Sep 4, 2009 | 01:42 AM
Wants a CBR's Avatar
Default Clutch adjustment?
I had some tires mounted and they adjusted my clutch. It used to grab real early, but the tech stated that was bad for the trans? He recommended something about a nickels worth of play. Meaning that it engages rather late. Stating that it would be less work on the trans fork. I like how it used to grab early.
It makes sense to me that grabbing early would reduce wear, but from what he was saying is the opposite. And truth to this?
Old Sep 4, 2009 | 07:31 AM
MartiniRossy's Avatar
The way I'm taking is logic is that by adjusting the lever to disengage the clutch later, less seperation of the discs is happening thus possibly still passing a bit of power through to the tranny, but that would seem, *** backwards to me?! I would think it would be worse for the shift forks to change gears under a load (like with no clutch) than completly free. Being too tight is not good though, but I would say more like a dime's worth of play.
Old Sep 4, 2009 | 04:12 PM
Aken's Avatar
July 2008 ROTM
Grabbing early means there is very little zone between fully disengaged (clutch pulled in - no power going to motor) and the start of the friction zone. If it were to wiggle out of place a bit (which it will do over time), you could have the clutch pulled all the way in but still be sitting in part of the friction zone. Which is where your wear and tear comes from.
I'd meet in the middle ground somewhere and just extend your grab point a little farther than you're used to.
Old Sep 4, 2009 | 10:26 PM
I get it now! Thanks man. Still ridin around Racine alone though... Hit me up man. 414.331.6069
Old Sep 5, 2009 | 02:41 AM
Aken's Avatar
July 2008 ROTM
I gave you the link to the local forums. Go check it out and find one of our weekend rides and come join I don't ride much in Racine, if at all.
toecutter2503
Jun 5, 2010 03:19 PM
Turbulenz
Apr 13, 2010 10:15 PM
asides
Apr 5, 2010 07:02 AM
sc929
Sep 27, 2007 05:57 PM
MapJr
Jul 19, 2005 08:54 PM
