clock on instrument panel
Old Mar 10, 2007 | 11:12 AM
pochop7's Avatar
Default clock on instrument panel
To start off I tried doing a search for this before I posted, but couldn't find anything. I just bought a 2003 CBR600F4I and my clock isn't set right and its bugging me everytime I look down. I don't have a manual on this bike so I was just wondering how to reset the clock to the correct time. Any help is appreciated. I was going to wait till lunch time and disconnect the battery, lol, but if I can avoid doing it the hard way I will.Thanks again.
Old Mar 10, 2007 | 11:52 AM
EPNF4i's Avatar
Default RE: clock on instrument panel
1. With the ignition on, press and hold both buttons for more than 2 seconds. Hour display will flash.
2. Press bottom button until desired hour and AM/PM are displayed
3. Press top button to display the minute. Minute display will flash.
4. Press the bottom button until the desired minute is displayed.
5. To end, press the top button or turn the ignition off. FYI adjustment will self cancell if no buttons are pushed after 30 seconds.
6. Don't just press buttons all " ***** Nilly" cause that's just lame! hehehe lol!
Hope this helps. Good luck and have fun!
Old Mar 10, 2007 | 11:56 AM
NeoClone's Avatar
Hey, dude, try this. I got it straight from my owner's manual (without the illustrations). It's from the '06 one, so I don't know if it's gonna work with the '03, but it's worth a shot:
1. Turn the ignition switch ON.
2. Press and hold both the select button and reset button for more than 2 seconds. The clock will be set in the adjust mode with the hour display flashing.
3. To set the hour, press the reset button until the desired hour and AM/PM are displayed.
4. Press the select button. The minute display will start flashing.
5. To set the minute, press the reset button until the desired minute is displayed. The minute display will return to "00" when "60" is reached without affecting the hour display.
6. To end the adjustment, press the select button or turn the ignition switch OFF. The display will stop flashing automatically and the adjustment will be cancelled if the button is not pressed for about 30 seconds.
Old Mar 10, 2007 | 05:19 PM
pochop7's Avatar
Ok, it worked, thanks for both replies!
Kurt Robert Lindqvist
Aug 27, 2012 07:58 PM
Johnathon Graddy
Feb 13, 2011 10:58 PM
smr123
Dec 28, 2007 05:02 PM
recker
Jul 10, 2007 12:30 AM
CBR600RRBLUE
Apr 7, 2006 08:34 AM
