Changing a throttle cable?
Old Sep 24, 2008 | 01:42 PM
ampfp's Avatar
Default Changing a throttle cable?
Anyone done this? Does the fuel injection need to be disconnected? any washers/rubber parts that need to be bought? any known PITAs?
The service manual only talks about taking off the entire throttle body, so I'm unsure as to what all I'll have to disconnect/depressurize.
Old Sep 24, 2008 | 02:13 PM
glacier_white_F4i's Avatar
Default RE: Changing a throttle cable?
to depressurize, remove the fuel pump fuse or disconnect pump and start the engine. disconnect negative batt terminal. remove tank and air box. then you can get to and remove the t/b's. from there you'll have access to the throttle cable for fanagling and eventual removal. no real pita's. just make sure everything is disconnected and remember where everything goes. good luck sir
Old Sep 24, 2008 | 05:02 PM
Tahoe SC's Avatar
i didn't do any of it. you can just remove the bolts, etc. and put the new cables in and then adjust accordingly.
Old Sep 24, 2008 | 06:39 PM
ampfp's Avatar
thanks for the info glacier.
Tahoe_sc, please elaborate? no tank/airbox/throttle body removal? [&:]
I just need to replace 1 cable. Quicker fixes are welcome since I need it track ready soon
Old Sep 25, 2008 | 08:43 AM
birdstrike's Avatar
You have to remove the airbox, but a good idea for the tank to avoid complete removal is to pivot the tank and hold it with bungees, heres a picture
http://cbrworld.net/forums/thread/270085.aspx
removing tanks is such a pain with a fuel injected bike.
Old Sep 25, 2008 | 11:22 AM
ampfp's Avatar
Thanks... will try that! (w crossed fingers)
Old Sep 26, 2008 | 04:53 PM
Tahoe SC's Avatar
i meant i didn't have to depressurize, etc. i still had to remove the air box to do it and whatever was on top to get to it. i held the thank up with some rope to the tail. if you have lots of gas, be careful, it'll come out.
Old Sep 26, 2008 | 04:57 PM
ampfp's Avatar
Thanks guys
airforce123
Apr 4, 2012 10:24 PM
Monty08
Jun 15, 2011 08:21 PM
cbr6rider
Apr 20, 2011 08:57 AM
some guy #2
May 3, 2008 08:33 PM
283racin
Apr 30, 2008 11:16 PM
