chain? & sprocket life?
How often do you guys change these?
sorry if this has been done b4. but would like new results so.
________
Sexy_Island_Girl
________
Sexy_Island_Girl
RE: chain? & sprocket life?
Depends on a lot of things.
Type of riding
How often you clean and lube it
How well it's kept adjusted properly
Type of chain and sprockets
If the chain and sprockets are stock size and materials and you do your maintenance properly (which I'm sure you do) then you can get over 10K miles out of them.
Type of riding
My stock chain lastedabout 16k miles before it was stretched to the limit of the adjuster. I got into regularchain wax/lubea li'l late, I guess damage was done. Now my bike is over 21k miles, stock sprockets are still going good and I clean and wax the chain regularly.
ORIGINAL: orags
OK. Cause my 03 F4i got like 11K miles or so on it, I think the chain and sprocket are stock and was wondering if you guys suggested that they were gettin a bit old??????????????????
________
LightRiver cam
ORIGINAL: F4iMane
ORIGINAL: FLYOU
the only way to tell if the chain needs replaced is if the placard on your swingarm tells you to replace it after a certain limit is reached. if you're at 11k, and if you have regularly cleaned and lubed her every few hundred miles, you've probably got a few thousand miles left on her.
ORIGINAL: F4iMane
________
IHNO
Bought mine new(zero miles).Lubed every 500 miles or once a week. Adjusted it every oil change(4k)..Mine had 20k on it before it started getting tight spots in the chain(sprockets still looked good).That is mountain riding,commuting and just overall hard riding.
Went with the rk steel sprocket kit (stock 525 chain,stock gearing)and have zero complaints. I recommend going with new sprockets and chain,even the old sprockets look good.For longer wear.
Look for tight spots,rust at the oring area,abnormal sprocket wearand noise at low speeds these are all signs you need a new chain.
ORIGINAL: white99gt
so you stayed with stock type. Thats cool. Probably will do the same. How much that run you and what were the individual amounts? New chain? sprockets?
________
Glass bubblers
