Chain Oilers
Old Apr 25, 2009 | 07:21 AM
NobleSandy's Avatar
Default Chain Oilers
Hello Riders,
I'm considering installing a chain oiler on my '02 F4 i.
Do any of you have experience with either the Scottoiler or Acumen chain oilers?
Can you suggest a source for a comparison test for these oilers?
Thanks for any advice you can offer.
Sandy
Old Apr 25, 2009 | 12:14 PM
Stephens's Avatar
Just spray chain lube or chain wax on it while you have it on a stand and thats good enough. Thats what I do.
Old Apr 25, 2009 | 07:17 PM
G3NESYS's Avatar
where do you get the white/clearish chain lube that comes on the chain when you buy a new chain?
i have chain grease but i dont like putting it on there because it sprays black grease all over the bottom of my fairings
Old Apr 26, 2009 | 01:22 PM
ibiggers's Avatar
I use Dupont Teflon spray...It's at Lowe's for like 5$ a can, and it drys in like 30minutes and doesn't sling. I use it because its good, not because its cheap.
Old Apr 26, 2009 | 01:31 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
+1 On the Dupont Teflon for chains. Goes on wet, then dries to a wax type lube with no fling.
My back slidding glass door used to be a pain to open; sprayed some of that stuff on the rollers and now it slides like butter. That's my independent test analysis
Old Apr 27, 2009 | 12:51 AM
nekidfrog's Avatar
dupont kicks serious ***!! it cleans and lubes all in one!! does not fling, and repells dirt longer than most chain lubes
Old Apr 27, 2009 | 05:31 AM
kukku's Avatar
Automatic chain oilers are only what the name implies - just oilers. You still need to inspect, clean and adjust the chain periodically. Also, do not take the reservoir for granted - many people run out of oil and never notice, hence causing more wear to the chain. I can however see the point when touring / long distance riding.
Old Jul 16, 2009 | 10:34 PM
DonF4i's Avatar
Which section of the store did you find this at so I dont spend 30 mins looking for it? Thanks!
Old Jul 17, 2009 | 12:38 AM
Uniqsol's Avatar
Is it this stuff?
Old Jul 17, 2009 | 11:08 AM
ibiggers's Avatar
I check my manhood at the door and ask for help. Haha. In Brewer, Maine (i know this is no help to you) it is near the tools in th front of the store. It had its on display stand.
