Chain Lube
Old Apr 12, 2010 | 12:05 AM
Holmesf4i's Avatar
Default Chain Lube
Hey there what do you guys recommend for chain lube? I had an old can of D.I.D something but i'm gonna purchase a new can tomorrow just seeing if you guys have any suggestions or a favorite product that you use? Any insight would be appreciated
Thanks, Nate
Old Apr 12, 2010 | 12:44 AM
usetheffours's Avatar
use wd-40
i've used a few different brands of spray on lube and like fuchs silkolene the best.
Old Apr 12, 2010 | 08:23 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
If there's a Lowe's by your house, you can pick up a can of DuPont Teflon Multi-Use Lubricant for $5.
It's all I ever use; good stuff.
Old Apr 12, 2010 | 08:26 AM
Holmesf4i's Avatar
Yeah WD-40 ill get right on that so.. thanks for the advice fellas im gonna go pick up a can of fuchs cause i don't have a Lowe's in my town.
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
Thumbs down
You ought to use the search button up above.
Old Apr 12, 2010 | 09:03 AM
kilgoretrout's Avatar
Administrator - Retired
Quit starting trouble, indy.
That's my job.
Now what's the problem with WD40??
Old Apr 12, 2010 | 09:24 AM
That's my job.
ANswer???
I just lilke this product better.
Old Apr 12, 2010 | 09:25 AM
regener8ed's Avatar
i prefer the spray chain wax.
p.s., here's a little home remedy tip: chain wax is the bomb for lubricating old locks. i have old padlocks I use outdoors that get really stubborn with time and weather. i used to put wd40 in them, but that only lasts a short while. i sprayed some chain wax in them several YEARS ago, and they still open and lock like a dream.
Old Apr 12, 2010 | 09:30 AM
johnnyx's Avatar
This question will get you as many solid answers as "Which oil should I use," but here's my point-oh-two:
So long as you're lubricating every 500mi like you're supposed to, and replacing your chain and sprockets at the right times, then pretty much every chain lubricant out there is gonna do ya. You may have to use a little more with some and less with others, but you'll come out the same in the end.
Old Apr 12, 2010 | 09:58 AM
CBRme's Avatar
+1 for chain wax i use it religiously and have never had a problem
