chain conversion
Old Mar 23, 2006 | 12:35 PM
7gregory's Avatar
Default chain conversion
I have a 2001 cbr 600 f4i that is bone stock. I want to do a chain conversion because I find the low end torque to be weak. Should I do a 1 down and 2 up or what do you reccommed. I don't care about going 160 mph. Just cant pop up front end that easy. also where to buy the kit cheap for high quality.
Old Mar 23, 2006 | 01:18 PM
SquireSCA's Avatar
Default RE: chain conversion
When you say coversion, that usually means to covert the drivetrain from 525 to a 520 size.
What you are talking about is a regearing. Changing the sprockets out to get more power down low at the expense of top-end that you hardly ever use anyway.
Vortex is the way to go. Good quality and cheap. You do not need a new chain or chain tool with some gear ratios. I went down 1 in the front and up 2 teeth in the back using the stock chain.
HUGE difference in power delivery, sometimes it is a pain to keep the front end down in 1st. Second is not that bad and the rest of the gears are perfect.
You can get the new front(-1) and rear(+2) sprockets for under $100 with shipping.
Old Mar 23, 2006 | 02:03 PM
snobrdrdan's Avatar
So you literally use the stock chain with the -1 in front & the +2 in the back setup??
You don't have to take out any links or anything?
But the speedometer will still be off
And the 520 is a different chain.....but what's the actual physical difference betweent the 525 & 520 chains??
Will the sprockets work with the stock 525 chain and a 520 chain. Like it doesn't matter?
Old Mar 23, 2006 | 03:51 PM
DThompson's Avatar
Yes you can literally use the stock chain with the -1+2 sprockets. If anything you would have to add chain links not take them out.
As for the 525 sprocket and 520 chain question.
NO!!!!!!!!!!!! You CANNOT do that. Your stock chain is a 525 so just get 525 sprockets.
The difference between the two is that the 525 is thicker than the 520.
You only need a 520 really if your racing and trying to shave off a little weight from the bike.
Also the 520 chain snaps easier then the 525 chain will.
Daniel Thompson
Old Mar 23, 2006 | 04:18 PM
Tahoe SC's Avatar
yea mang...but if you get DID...no snapping!
520 will wear out faster than 525...the difference is in the pitch/width.
weight wise, sounds like you'll save lots on rotational mass, but dude, i couldn't tell ****E!
Old Mar 23, 2006 | 05:06 PM
SquireSCA's Avatar
Yeah, I used the stock chain. Didn't have to mess with it at all.
And the speedo will be off. If you do a -1/+2 regearing, your top speed is around 135mph actual, but the speedo will say 160 or so. So you will need a Speedohealer.
Old Mar 24, 2006 | 02:54 PM
snobrdrdan's Avatar
Uh huh...thanks guys!
Yeah I figured that if you offset the sprockets, by going smaller in the front & a lil' bigger in the back, that the chain length might not change much but I didn't know that you could use the stock chain still.
So you just get a 525 -1 front & a 525 +2 rear and then bolt them on and put the stock chain back on and adjust the tension, that's it??
(sounds simple)
And yeah I also read that the 520 sprocket/chain combo does wear out quicker. I didn't know that people did it for weight reduction though....sounds a little extreme. It's maybe a couple pounds......for racing I could understand, but for the street not really.
Another question......what if you JUST went 1 tooth smaller in the front (and got a shorter chain)???
Would that be faster than the -1 front, +2 back setup??? Or what would the difference be??
stampern
Jun 20, 2011 12:31 PM
SLOrider954
May 15, 2011 04:17 AM
fastspares
Mar 22, 2010 02:29 PM
mtxkidd2
Sep 30, 2007 12:18 AM
XLSR954
Feb 24, 2005 08:18 AM
