Cct bolts- help
Old 03-06-2021, 07:21 AM
roundyuk's Avatar
Yup, 6x25 hex head bolt and 6mm copper washer...I like Fowlers parts fiche below, gives you a lot of the sizes for bolts etc.
https://www.fowlersparts.co.uk/parts...chaintensioner
Old 03-06-2021, 11:41 PM
Zac May's Avatar
UPDATE: I finished throwing em in, used a little silicone sealer and a washer for it. Thanks for the help all!
Old 03-07-2021, 04:57 AM
Good one, did you notice much difference after the change?
Was it rattling really badly in the first place or was the change precautionary?
Old 03-09-2021, 11:29 AM
Scott91370's Avatar
How in the world did you get the CCT out? I had the tank and right side fairing off and still couldn't get access to loosen the bolts (tried u-joint & wobble extensions). Mine rattle like crazy and I really need to change it.
Any tips would be GREATLY appreciated!!
Old 03-09-2021, 11:34 AM
this might help
The following users liked this post:
Scott91370 (03-09-2021)
Old 03-12-2021, 11:56 AM
roundyuk's Avatar
I found this guide really useful, but it's all about taking your time and patience.....and a smidge of luck not dropping bolts! https://www.bayarearidersforum.com/f...threadid=81780
I used a small 1/4" drive ratchet, extension bar and universal joint, mixture of hole through the frame, from above and fingers. Had it all done in less than 2hrs I reckon.
Al1040 (03-12-2021)
Old 03-12-2021, 05:51 PM
boredandstroked's Avatar
Remove airbox and throttle bodies.
Old 03-13-2021, 06:22 AM
roundyuk's Avatar
You really don't need to remove the airbox and throttle bodies, yes it will probably give more access but its a lot more work!
Old 03-13-2021, 08:36 AM
Old 03-13-2021, 08:28 PM
Zac May's Avatar
The rattling was REALLY bad in the first place, huge difference 😂😂
Quick Reply: Cct bolts- help
