Cct bolts- help
Old 03-04-2021, 09:10 AM
Zac May's Avatar
Default Cct bolts- help
I have lost one of the cct bolts that hold it on the engine and I’m wondering if it HAS to be that exact bolt and if there HAS to be the sealing washer on it. Tried to order new ones but they are taking months. Thanks in advance!
Old 03-04-2021, 09:38 AM
No it does not have to be the exact same bolt. It's a standard cap head 6x25 bolt that you can get easily at Ace Hardware. Remember to wind the tensioner back in before reinstalling it.
The following users liked this post:
Zac May (03-04-2021)
Old 03-04-2021, 09:52 AM
74demon's Avatar
If the threaded hole goes all the way through, then the bolt must be sealed. In absence of the sealing washer, a small dab of silicone sealer on the threads will do.
Old 03-04-2021, 12:16 PM
Zac May's Avatar
alright cool! I’ll stop over there and see what I can find. Thank you!
Zac May's Avatar
alright thank you! I’ll grab some silicone sealer on the way home!
Old 03-04-2021, 12:34 PM
You understood what I meant by winding it back in before installing, right? Just checking...
Old 03-04-2021, 12:36 PM
Zac May's Avatar
yes, I bought a whole new cct that comes winded up. But thank you for checking 😂😂
IDoDirt (03-04-2021)
Old 03-05-2021, 12:33 PM
roundyuk's Avatar
I just did this job on my '02 F-Sport, defo needs sealing; original bolt has a little washer on it.
Not a fan of silicone, its just a 6mm sealing washer you need to find.
The washer under the bolt that goes into the end of the CCT is a defo replace, its a crush washer and you know it'll leak if you don't :-D
Old 03-05-2021, 09:17 PM
Zac May's Avatar
I can just buy a 6mm sealing washer from ace and call her good?
Old 03-06-2021, 04:48 AM
Yes you can, their is nothing special about the copper crush washers.
Quick Reply: Cct bolts- help
