One year now i never had any issues with those but something always bugged me, do you place the LEDs with the light stripes looking up and down or left and right? LEDs stripes facing left and right
Your question is in fact a very good one and is most of the time the cause of bad purchaches of headlamp LED's.
As you can see above, I have drawn a headlamp reflector as a basic principle. When a normal bulb is installed the light will reflect the way it is designed.
This is how the reflector (or lens) is designed and this will give the least amount of random lightoutput ("strooilicht" in Dutch).
Therefore using the original lightbulb gives the smallest chance of blinding our fellow road users. Or getting attention from our big law enforcing friends.
Now changing the bulb for a LED will almost certainly disrupt the functionality of the reflector. But the question is how much. First of al it is important when buying a LED that the point of light exit is as small as the light emitting wire from the halogen bulb itself. Because a lens or reflector is focussed on that point alone. When the light emitting part gets out of this area so will the lightbeam that comes out of the headlamp.
Therefore I can already tell with quite some certainty that your LED does not perform as should on the road.
Now the part with the 'blind spots' on the LED itself: When the blind spot of the LED is pointed to the sides, there is quite a chance that the sides of the headlamp image is disrupted. When placing the blind spots vertically there is quite a chance that the length of the beam is disrupted.
Personally I would experiment by doing an experiment by placing your bike in 10m in front of a wall.
Check the headlamp imange with a normal bulb.
Then replace the halogen bulb with an LED an turn it in the ways you can and compare it to the image you saw with the halogen bulb.
Look for the image that is most comparable to the halogen bulb.
Most important is that there is a very sharp line above the lightbeam. Above it should be hardly any light and below it should be a full complete and wide beam.
If you want a more complete story then watch this:
I didn't change the halogen headlights on my motorcycle, but I replaced them with LED for my car. I bought those angel eyes for my Ford, and I love how they look like. I bought beamtech LED headlight bulbs for the car, but I will choose Philips, guys, as you said for the motorcycle. I can find them easily on Amazon, as I found these LED car lights
