Bypassing Bank Angle Sensor
Old Feb 28, 2007 | 01:46 PM
Jaybird180's Avatar
Default Bypassing Bank Angle Sensor
I’ll be sending my bike to the shop soon. During it’s time in the shop, I will be working on the plastics, so I won’t be able to just give them the bank angle sensor (or can I???). I read on another forum about splicing red and green, but the poster didn’t seem too clear. Does anyone know how to jump the harness in order to bypass the sensor so they can run the motor?
Old Feb 28, 2007 | 11:54 PM
lamby's Avatar
Default RE: Bypassing Bank Angle Sensor
on the wiring at the left side of the bike. around the ram air there is a bunch of wires connected to a gray plug. splice green and red and youre good
Old Mar 2, 2007 | 12:31 AM
Jaybird180's Avatar
Then I should be able to jumper the pins to avoid cutting the harness. Thanks.
Old Mar 2, 2007 | 05:06 AM
lamby's Avatar
yeap i jumped mine
Old Mar 2, 2007 | 07:19 AM
ddaren's Avatar
does anyone have a good picture describing where the bank angle area is?
I rememberwhen I first got my bike (back when I didn't know how to do anything to it), my fuel pump didn't prime and couldn't start my bike. Took it to the shop and they told me there was a faulty ground wire in the bank angle area which caused the fuel pump to not get power.
I want to know where this area is so next time it happens, I know what to fix.
Old Mar 2, 2007 | 03:10 PM
lamby's Avatar
if you are keeping your headlight on its attached to the headlight. take off the windscreen and its right behind the cluster. its a black box with a red,green and white wire. i jumped the wires from the main harness cause i run streetfighter sometimes, but you can jump it from there if you want
maksim
Dec 7, 2014 12:33 AM
roaddog
Jul 18, 2011 04:28 PM
Phatcbr
Oct 19, 2010 09:37 AM
itsgroll
May 11, 2010 09:32 PM
elkakandkss
Mar 17, 2006 02:45 PM
