buzzing noise
2001 cbr600 f4i
when i am on the highway or somewhere that i am accelerate really fast and then let go of the throttle i hear a buzzing noise. i often think it is some one honking at me but its not al loud as a horn. loud enough for me to hear though. what the hell is it? also i had a mechanic tell me i need to change my cam chain supposedly it has been a problem with this year bike. any info? |
RE: buzzing noise
buzzing? dunno mang...cctl not cam chain, but the cam chain tensioner lifter is what you should change...but that sounds like bb's in a can...rattling, not honking...but it could be a buzzing...
RE: buzzing noise
I think I know what you are talking about. It's kind of a low hum that isn't engine noise? My '05 does it, and I've always thought it sounded like intake noise. I've wondered about it, but bike runs great (and I've got an extended warranty), so I'm not going to worry about it.
RE: buzzing noise
its only when i accelerate and the rpms are by 10k and they are winding down. usually around 90-110. slowing down...
its not a honking noise it is a buzzing noise. is the cam chain tension lifter expensive or hard to replace? |
RE: buzzing noise
so is it a rattling hum? CCTL will do it in all gears (engine loaded)...do this...go first or second...run it up to like 10K and then let go of the throttle, you'll feel crazy arse vibration from the tank area....vibrating hard that it can sound like a hum...that's the cctl.
well...it's hard to get to if you don't take off the tank...replacing it isn't hard, it's getting to it that is...but totally doable. the part itself is like 45 bucks for a manual one and about the same for a factory one (i get hook ups). i don't mind replacing the stock one every year or so, gotta get in there anyway for other stuff ya know?! |
RE: buzzing noise
i also get a hook up for cost at a dealership.and it sounds like buying the part won't be too bad. and taking the tank off isn't a problem either. i got the bike a month ago and i took it apart and put it back together a bunch of times already.
sounds like it is the cctl thanks bro. |
RE: buzzing noise
you don't need to take it off completely, just enough to get it out of the way...dunno why, but i gots lots of slack with my fuel lines and stuff attached...but some people have like none!
RE: buzzing noise
check your drive chain slack
RE: buzzing noise
ORIGINAL: Tahoe SC so is it a rattling hum? CCTL will do it in all gears (engine loaded)...do this...go first or second...run it up to like 10K and then let go of the throttle, you'll feel crazy arse vibration from the tank area....vibrating hard that it can sound like a hum...that's the cctl. well...it's hard to get to if you don't take off the tank...replacing it isn't hard, it's getting to it that is...but totally doable. the part itself is like 45 bucks for a manual one and about the same for a factory one (i get hook ups). i don't mind replacing the stock one every year or so, gotta get in there anyway for other stuff ya know?! -Jesse- |
RE: buzzing noise
no mang...said it feels like it's coming from the tank. cctl will let you know if it's bad...but yea...pretty much feels like the tank has crazy vibration...rattilng, etc.
