Break Lines
Old Feb 5, 2013 | 05:08 AM
swaskowiak's Avatar
Default Break Lines
can someone suggest a good set of steel break lines for the F4i?
Old Feb 5, 2013 | 10:48 AM
upgradedcbr's Avatar
Spielger makes a great set of lines in braided stainless steel. They have a variety of colours for both fittings and lines as well.
Spiegler Performance Parts - Motorcycle Performance Parts | Custom Motorcycle Accessories
Old Feb 5, 2013 | 10:51 AM
swaskowiak's Avatar
Cool I'm going to check them out when I get home from work.
Old Feb 5, 2013 | 03:17 PM
Aken's Avatar
July 2008 ROTM
+1 for Spiegler.
Old Feb 5, 2013 | 04:36 PM
RudyGT's Avatar
awesome i've been wanting to find some braided steel brakes
Spiegler Performance Parts - Performance lol wut?
hey on the page it says alt 2 line for the f4i part, but when looking at the pictures of different types it is actually 2 lines over the fender... err its 3 lines with a fitting
Old Feb 5, 2013 | 06:42 PM
MadHattr059's Avatar
While you won't go wrong with Spiegler, really, any braided line is fine.
This is a fully mature product, nobody makes a bad one.
This is one of the few upgrades, where I recommend price as the top priority.
Other consideration is color, if you're into the potential 'bling'.
Be sure if you that you include new crush-rings, in the upgrade.
As well, any banjo-bolt changes you may need.
Some bikes use a distributer above the calipers,
so they use one line from the MC to the distrbuter and then split to the calipers.
Most kits use 2 lines at the MC, running to each caliper, directly.
This will neccessitate changing from a single to a double banjo-bolt.
Also, 3 instead of 2 crush-rings.
Old Feb 5, 2013 | 08:38 PM
RudyGT's Avatar
they don't list any master cylinder or reservoir for the f4i, are they universal? they are certainly expensive.
so spielger's are two brake lines looks like you need to ditch the existing setup and go with a new master cylinder plus a reservoir.
fine by me if the existing equipment is faulty but i imagine brakes fade no matter what, and when you upgrade you are just buying an
adjustment to make the pull the same on the lever when it does.
or am i wrong, under alot of braking does the factory cylinder allow you to pull the handle all the way to the throttle?
sorry for hijacking but those brake lines seem incompatible to the f4i, or is that where the double banjo bolt comes into play?
Aken's Avatar
July 2008 ROTM
Spiegler kit should come with everything you need to swap. My Galfer kit did (another good brand), I don't see why they wouldn't also.
Edit: You don't need to replace your master cylinder.
Old Feb 6, 2013 | 10:38 AM
boredandstroked's Avatar
Exactly. I suggest everyone buys whatever is on sale. Thats how I ended up with goodridge lines.
Old Feb 6, 2013 | 05:25 PM
RudyGT's Avatar
yeah my parts guy just ordered me up some, said they come with everything i need but don't come with clips or mounting brackets, free floating system.
from what i hear the steel braided lines themselves prevent brake fade because your regular rubber lines expand, a good upgrade and spiegler is a good brand.
