Braking = Gear Downshifting?
Old Jul 6, 2006 | 04:49 AM
MaverickPrince's Avatar
Default Braking = Gear Downshifting?
Hi all... been riding an '01 stock F4i for a few months now... and on the rare occasions where I've had to stop rather abruptly to a complete stop... (appying brakes 75% front and 25% rear) it "appears" that my bike gears down on itself? e.g. I'm in 2nd gear and try to stop, then I can hear a distinct "ka-chunk"...
Does this make sense (or some kind of feature or reaction)?
Mind you, it all happens rather fast and I'm just worried about getting to a stop in that exact instant, so just thought I'd post here to see if there's any substance here...
Comments?
Thanks...
Old Jul 6, 2006 | 05:16 AM
_PJ's Avatar
_PJ
Default RE: Braking = Gear Downshifting?
i've heard something like that once.. i would think it's more likely a chain noise it makes when you try to shift quickly from accelerating to braking
in my case, it was probably because my chain had to much free play and needed to be tighten up
Old Jul 6, 2006 | 11:44 AM
Jaybird180's Avatar
If you've taken MSF it may be the reaction drilled into you subconscious. Or panic reaction pressing down with both feet :-)
Old Jul 6, 2006 | 12:05 PM
Fox's Avatar
Fox
No noise here.
Old Jul 6, 2006 | 12:15 PM
ejohn's Avatar
if you press hard enought to break loose the rear tire you will hear the slack in the chain making noise. try this as your riding to see if this is what your hearing.
Old Jul 6, 2006 | 12:39 PM
Jaybird180's Avatar
ORIGINAL: ejohn
I wouldn't do that if I were you. If the tire breaks traction you run the risk of a highside. Or if it grips at the wrong moment you at least cause extra wear/tear to chain and sprokets. I've heard some say that rough downshifting can even cause the engine to rotate backward for a split second, but that sounds fishy to me.
Old Jul 6, 2006 | 12:40 PM
Fox's Avatar
Fox
Oh I understand.
When the tire is breaking traction? As if is too cold, right? I've done that before. A slipper clutch would prob. solve that problem.
Old Jul 6, 2006 | 03:22 PM
SkinnyJ's Avatar
i dont even know if i understand the question lol. are you pulling in the clutch when your stoping abrutbly?
Old Jul 6, 2006 | 04:43 PM
Fox's Avatar
Fox
ORIGINAL: SkinnyJ
When the tires are not to operating temp and you quickly downshift into a lower gear and release the clutch or locking the rear tire. The whole rear subframe hops and makes a clunking sound.
Old Jul 6, 2006 | 05:38 PM
Jaybird180's Avatar
ORIGINAL: mikem317
Too bad no one makes one for the F4i
