Brake FLuid
Old Aug 26, 2008 | 03:52 PM
travsstuff's Avatar
Default Brake FLuid
My brake fluid is a little low, can I just add fluid (dot 4).....Or do I need to drain and refill....and does it matter what kind....
Old Aug 26, 2008 | 04:21 PM
Xuracing's Avatar
Default RE: Brake FLuid
It does matter what kind. Always use Dot4 you can just top it off. You don't need to drain it. If it seems a little murky or there's something in it i would recommend draining it but its not required.
Old Aug 26, 2008 | 04:32 PM
travsstuff's Avatar
ORIGINAL: Xuracing
awesome....so it doesnt matter if i mix brands, all that matters is dot 4???
Old Aug 26, 2008 | 04:38 PM
Xuracing's Avatar
yes. DOT4 is Dot4 its the same stuff there are standards so everything is made basically the same it will be fine!
Old Aug 26, 2008 | 04:49 PM
travsstuff's Avatar
Thanks
Old Aug 26, 2008 | 07:12 PM
MC_spirited's Avatar
You dont drain it. If your fluid is low, its old and dirty. Get a piece of 1/8th ID tubing. Connect it to the bleeder valve. Fill up the reservior and put the cap back on. Apply pressure to the brake and open the bleeder. Repeat until the fluid looks clear coming through the tube. Make sure to bleed the air out, get a nice stiff lever and you're done.
johnnyx
Aug 22, 2012 01:15 PM
CJardine
Jul 24, 2012 09:41 AM
ThisisMickey
Aug 24, 2007 03:38 PM
tutman6
Aug 27, 2006 01:23 PM
hondacbr1000
Jul 22, 2006 06:41 PM
