bout to change the oil question
Old 06-30-2006 | 01:36 PM
ninetyfivehp's Avatar
Default bout to change the oil question
who here actually torques the oil drain plug to 22 ft/lbs? that seems pretty damn tight for a 12 mm bolt. also should i change the crush washer. thanks. is it necessary to remove the right side fairing to get to the filter?[sm=icon_cheers.gif]
Old 06-30-2006 | 01:49 PM
otisbrown's Avatar
Default RE: bout to change the oil question
I use the general rule tight is tight too tight is broke. Never replaced teh washer. You can get teh oil filter out with out pulling the ferrings off, but you will spill some oil on the middle of both farings. Tends to get real grimey after a couple of rides.
Old 06-30-2006 | 02:55 PM
skeelo's Avatar
It's a good idea to put in a new crush washer.
Old 06-30-2006 | 03:15 PM
Wilson1's Avatar
I have changed the oil without replacing the crush washer with a new one, and never had a problem. It's a lot easier to just buy like ten of them, and not have to worry about it tho. Also, just kind of snug the bolt on there. It doesn't take much. I doubt mine has ever been at 22 lbs., and it has 13k miles on it.
Old 06-30-2006 | 03:34 PM
Jaybird180's Avatar
Stop being a Cheap A$$ and change the washer. One less thing to worry about.
Old 06-30-2006 | 03:39 PM
christhek's Avatar
Fairing don't have to come off to get to the filter. Never tourqed the drain plug nor replaced the washer on any vehicle for the past 20 years.
Old 06-30-2006 | 04:34 PM
so finger tighten then about how much of a turn with a 3/8" ratchet for the drain plug? just don't want a **** it up as the bike is new. thanks[sm=icon_cheers.gif]
Old 06-30-2006 | 04:37 PM
i'm a pretty cheap bast@rd but i'm gonna use a new crush washer per you guys advice. thanks again[sm=icon_cheers.gif]
Old 06-30-2006 | 05:47 PM
ORIGINAL: ninetyfivehp
anybody?
Old 06-30-2006 | 05:50 PM
Jaybird180's Avatar
I think 22ft/lbs was thrown around on this board somewhere. But I'm sure you can look it up to be certain.
