Bikes been sitting, key won't turn to start
Old 05-23-2014 | 05:54 PM
RekTek's Avatar
Default Bikes been sitting, key won't turn to start
So I have a small problem with the 05. It's been sitting for 2 years. It has been getting started but not for about 6 months now. I noticed I accidenty left the key in the run position somehow. The battery has been removed for the winter and after turning the key off it now won't spring into and out of the start position. It easily and smoothly goes into the lock and run position but won't turn into the start. I'm not trying to start it a the moment since the battery isn't even in but can't figure out why it won't spring into and out of the start position. Any ideas?
Old 05-27-2014 | 04:20 PM
boredandstroked's Avatar
Originally Posted by RekTek
It easily and smoothly goes into the lock and run position but won't turn into the start. Any ideas?
Its not a car, there is no start. There is on, and off. Thats it.
Old 05-27-2014 | 09:42 PM
Sprock's Avatar
Don't forget that little button on the right control too
Old 05-27-2014 | 11:36 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
I think it has been sitting for so long you forgot how to start it. Turn the key ON and press the start button.
Old 05-28-2014 | 01:30 AM
Congee's Avatar
Are you saying that the key won't turn to the run position?
There are 3 modes, lock, off, and run. Which mode are you saying the key won't turn to?
Old 05-28-2014 | 07:35 AM
RoadiJeff's Avatar
Apparently, the position that does not exist.
Old 05-28-2014 | 09:52 AM
RekTek's Avatar
Ha! I did forget what the three modes positions are. It won't go from off to start. For some reason I remembered holding the key in the start position and pushing the start button simultaneously. Maybe I should put the retard sticker back on that identifies the key positions. So it will easily go from the lock to off position but not into the RUN position. It just stops dead at the off position.
Old 05-28-2014 | 11:46 AM
lol ok thats different. Have you tried spraying a little lube into the cylinder? Does the key still open the gas cap and seat ok?
Old 05-28-2014 | 12:53 PM
Congee's Avatar
My ignition is also a little funny. You can to to push the key inwards (down) while wiggling it and turning. You can also try straitening the front wheel, perhaps the wheel lock is interfering somehow.
Old 05-28-2014 | 01:11 PM
dman007's Avatar
Registered Users
I'd try some wd40, hopefully it loosens up whatever is causing the binding. Are you able to remove the key?
Quick Reply: Bikes been sitting, key won't turn to start
