Bike wrapup
Old Jun 12, 2017 | 03:28 AM
CaBaRet's Avatar
Hi, for setting time
Old Jun 12, 2017 | 10:47 AM
xifer's Avatar
the display is only showing -- [A] i cant set the time using that method
Old Jun 12, 2017 | 11:52 AM
CaBaRet's Avatar
Sorry about that presumed it was just the time setting your after, anyway have you got all the major 9, 10 and 12 pin connectors joined as it needs to make that circuit around the bike and to and from the ECM, and is the "B" 10 amp fuse OK as regards the clock
Old Jun 12, 2017 | 11:59 AM
xifer's Avatar
i sprayed all the major connectors and unplugged replugged etc, i havent checked fuses though... where is that?
Old Jun 12, 2017 | 12:07 PM
CaBaRet's Avatar
Under neath the seat to the front, you should find all the fuses under there , from 10, 20 and 30 amp ,check them all especially the 10amp fuses B, there should be some spare ones in there if they haven't already been used
Old Jun 12, 2017 | 09:21 PM
xifer's Avatar
i checked the clock fuses they seem fine?
Old Jun 12, 2017 | 11:47 PM
xifer's Avatar
i disconnected my instrument cluster and looked the fuses and everything seems fine? could the speedo have gotten fried?
Old Jun 13, 2017 | 12:14 AM
CaBaRet's Avatar
Was it working before you stripped everything down
Old Jun 13, 2017 | 12:19 AM
xifer's Avatar
yes and it worked as i stripped it down then it randomly stopped working
Old Jun 13, 2017 | 12:37 AM
CaBaRet's Avatar
Hi , time for the multi meter ,Try this test and it will show if there is a open circuit on wires.
