bike wont start?
hey i am new to these things and im rebuilding my f4i. i took just about everything off of it(tank, front cowl, etc). it started two days ago but i guess when i was wiring the turn signals i left the light on or something. it will try to turn over and then start clickin real fast. is this the battery drained or did i cross some bad wires or something?
Is your headlight connected? You need to have the bank angle sensor connected to get the motor to turn on. Otherwise it will just sit and turn over forever.
Hey Aken, Just out of curiosity...is the bank angle sensor up in the headlight cowl? and if it is, is it wired with the turn signals constant power? You mentioned that without it the bike will keep turning over but never start. Is that because the FI pump won't run without the BA sensor?
Thanks! Mike |
