Better cornering
Old Sep 23, 2007 | 08:29 PM
xtremef4i's Avatar
Default Better cornering
So after riding my buddy's 2006 R6S, I realized that his bike is very easy to frick into a turn where my 2001 F4i takes a little more effort to turn in. Is there anything I can do tomy bike to help it turn in a turn with less effort? I have already adjusted my suspension to the reccomended settings from Sport Rider
Old Sep 23, 2007 | 08:39 PM
Ace_f4i's Avatar
Default RE: Better cornering
better tires + steering damper + galfer wave rotors + rebuilt forks + forged mag/carbon fiber rims. i dunno man most of that stuff is pricey. it took me a while to find the best riding technique on mine. it was easier to put my knee down on my other bike.
Old Sep 23, 2007 | 08:47 PM
02cbrf4i4u's Avatar
+1
Check your tire pressure regularly.
Old Sep 23, 2007 | 08:53 PM
jmdaley's Avatar
Aggressive profiled tires like the Michelin PP and some others will help give you that "fall into a turn" feel. If your tires are old or flatspotted (or both) just getting new tires will make a big difference.
Old Sep 23, 2007 | 08:56 PM
.HoUnD.'s Avatar
I have mine set like this... It flicks in really nice. Took me a while fiddling with the suspension to get it to this point. Actually just finished today dialing in the turn ins. She is on rails now =) I'm 6.0 195 lbs.
5 Rear pre-load
3 lines showing front preload
Front Rebound = .75 turn out from full stiff
Front Compression = .60 turn out from full stiff
Rear Rebound = .65 turn out from full stiff
Rear compression = .45 turn out from full stiff
These numbers seem wierd I know. I started at a 1/2 turn out on all and tweaked from there. So you know .45 would be a little less then 1/2 turn out so forth and so on.
Lots of tweaking =)
Michelin PP's will also help with turn in but suspension has more to do with it then anything. Low tire pressure will also hinder turn in a bit.
Good Luck.. Oh ya btw... these bikes will never feel like a r6 or RR.. cus there not.
Old Sep 23, 2007 | 10:43 PM
xtremef4i's Avatar
I am about due for tires. In my part of Ohio they get flat spotted pretty easily. So the Michelen PP's ahve better turn in than the Dunlop Qualifiers? I am more of a Dunlop man personaly
Old Sep 24, 2007 | 11:12 AM
Tahoe SC's Avatar
FYI...if you're anything over 150-160, you're over what the stock suspension can do for you. an F4i will never feel like an R6 (old skool) or the new R6S...they are just very flickable by nature...but have you noticed how much more stable the F4i feels in the corner? tracking both, i liked how flickable the R6 was, but i loved the stableness/neutrality of the F4i. one feels like you're riding on top of it, the f4i feels like you're riding in it...as previously stated, tire profile will aid tons in how the bike feels in turns. PP will make the bike dive in faster...which is something you may like or dislike.
Old Sep 24, 2007 | 12:13 PM
Jaybird180's Avatar
R6 has more of a BMX bike feel IMHO. PPs on F4i won't necessarily help with initial turn-in, but once it's cranked over it will tend to want to stay there and continue to fall. Some people don't like it, but it forces the rider to use maintenance throttle to balance the bike in the lean and to maintain the desired line.
You can tweak the geometry to alter the turn-in characteristics, but keep in mind that you are balancing stability vsflickability.
Old Sep 24, 2007 | 12:29 PM
Tahoe SC's Avatar
tru dat bird...you can also lower the front or raise the rear to help turn in, but then you sacrifice stability for it...it's all give and take...but nothing is better than a good rider...that's why just about any motogp rider can whoop any advanced non-pro racer, whileon a stock bike not even suited to his weight, etc.
Old Sep 24, 2007 | 12:45 PM
slip_'s Avatar
Kiss your mirrors lol
yumoncbr
Jan 19, 2012 07:47 PM
halomatic
Aug 23, 2010 12:29 PM
woo545
Jul 18, 2008 07:55 PM
MDZ600F4i
Sep 17, 2006 11:30 PM
Silent Bob
Feb 18, 2006 08:45 PM
