Best Rear Tire?
Old 06-20-2007 | 03:38 PM
koelzer18's Avatar
Default Best Rear Tire?
Which Tire would you all recomennd.
Old 06-20-2007 | 03:43 PM
schultzy's Avatar
Default RE: Best Rear Tire?
im really happy with the michellin pilot powers that came on my 06' f4i. they are harder in the center with a softer compound on the edges for mo better grip
Old 06-20-2007 | 03:50 PM
ninetyfivehp's Avatar
did you buy it new? my 06' came from the factory with circa 2000 model d207's[:@]i'm gettin a rear tire friday (freakin nail) and a friend works at the dealership and also club racesrecommended the pp or the qualifer. said both were about the same. i'd go with the pp's but my front d207 only has 1500 miles on it and the guy recomended the qualifier because the profile would match up better with the d207
Old 06-20-2007 | 03:56 PM
600f4i_blackout's Avatar
I have d208GP's and sometimes in the corners it feels like it's starting to break loose, so i'm a little concerned with them. Next season i'm going to switch to metzler's (M1 or M3 not sure yet)
Old 06-20-2007 | 04:09 PM
Tahoe SC's Avatar
diablos...
Old 06-20-2007 | 05:24 PM
Jaybird180's Avatar
I had D208's (not GP's) and only had problems on left side (go figure).
I'd recommend that you at least stay in the same brand/series if you're replacing only 1 tire. Also ask around for used and you may even be able to match wear rate.
Old 06-20-2007 | 06:24 PM
lamby's Avatar
ORIGINAL: schultzy
the 2cts just came out this year...
Old 06-20-2007 | 06:27 PM
my d208GP's seem to be wearing differently on the left side of the rear then the right side, i'm not exactly sure why. any suggestions?
Old 06-20-2007 | 06:42 PM
Tahoe SC's Avatar
rear tire misaligned? you take more left turns than rights, etc. it's not going to wear exactly the same.
Old 06-20-2007 | 06:49 PM
I'm gonna check the alignment, but it is a noticable difference between the two sides. I was thinking of the possibility of more left turns then right, or maybe i'm not leaning as hard in left turns as I am in right turns...
