best HID kit to go with for the f4i
yes, hid's work in the high beams...just get a car kit, because both bulbs are the same..i forgot what type though.
DDM kits +1...
http://www.ddmtuning.com/
DDM kits +1...
most HIDs are plug n play. they have a little adapter pice that plugs to the harness anbd u just plug in the ballsts and bulbs and fire it up. and as for the high/low beam thing u can get dual fillament bulbs. they will cost u a little extra but u will have high beams, as most kits, esp ebay ones, only work on low. i paid $20 for a set of 2 9003/h7 bulbs. 600k low beam and a regular hallogen high beam. and they work great.
On a side note, those dual filiment bulbs are crap. The light source for the highbeam is never at the right spot to properly reflect and therefor you end up with a practically useless highbeam.
were could i get the relay harness from?..... and for a car dowes the relay harness have to plug into both stock harness light plugs or no???? as for my f4i i understand i need a relay harness for both low and high beams being that they are seperate bulbs unless i make them both go on at the same time right????
did you get the 55w or 35w? im curious to see how big of a difference, and is it worth it? im considering ordering from ddm as well.
